Hey, In my InfluxDB I have DB “x” and there I have MEASUREMENT “data” with 2 IP’s in STRING, I wanted to display those 2 strings inside grafana - ( once every 3 months they will swap and wanted to create grafana alert based on that ) - any idea what kind of chart to use for displaying it ?
The most straightforward would be a table, but that may not be the “look” you’re after. You can try singlestat, or the status panel plugin (latter definitely works for displaying strings from Influx, but may need tweaking)
Hey, I just used a simple SQL query to do that after all; - also connected it with diffrent table and hide things (columns) I didn’t want in settings.
Topic can be considered closed.
