I use the version 9.5.1 -
In the context of security measures, the Grafana version should be hidden in the login screen.
Since I use Docker, an environment variable must be set for this. The documentation says that the variable version_hide=true must be set.
Here (Configure Grafana authentication | Grafana documentation) this variable is under the category authentication. Here (Configure security hardening | Grafana documentation) it is under the category security headers. -
I tried the variable GF_AUTH_HIDE_VERSION=true in the container. Unfortunately without success. -
What happened?
The version is still displayed in the login screen. -
The version is not displayed in the login screen.
Which variable must be used here?
