dietpi 7.5.2 debian bullseeye
docker container grafana latest -
start docker container successfully -
docker-compose -
What happened?
container doesn’t start -
container run -
grafana:
image: grafana/grafana:latest
container_name: grafana
restart: always
user: “1000”
network_mode: host
volumes:
- ./grafana/data:/var/lib/grafana # data path
- ./grafana/provisioning:/etc/grafana/provisioning
- ./configfiles/custom.ini:/etc/grafana/grafana.ini
environment:- GF_INSTALL_PLUGINS=grafana-clock-panel,grafana-simple-json-datasource
- GF_SECURITY_ADMIN_USER=${GF_SECURITY_ADMIN_USER}
- GF_SECURITY_ADMIN_PASSWORD=${GF_SECURITY_ADMIN_PASSWORD}
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Error: ✗ Get “https://grafana.com/api/plugins/repo/grafana-clock-panel”: dial tcp: lookup grafana.com on 127.0.0.1:53: read udp 127.0.0.1:55701->127.0.0.1:53: read: connection refused
Error: ✗ failed to create temporary file: open /tmp/376482387.zip: permission denied
Error: ✗ failed to create temporary file: open /tmp/112431570.zip: permission denied
Error: ✗ failed to create temporary file: open /tmp/506707309.zip: permission denied
Error: ✗ failed to create temporary file: open /tmp/746178320.zip: permission denied
I use grafana as part of my home assistant docker install. Yesterday I have upgraded debian buster to debian bullseye. Exact the same config has worked fine before.
The data files are stored as user 1000 (dietpi) and the user can create files in tmp.
dietpi in DietPi in ~ ✦ ❯ id
uid=1000(dietpi) gid=1000(dietpi) Gruppen=1000(dietpi),4(adm),5(tty),20(dialout),24(cdrom),27(sudo),29(audio),33(www-data),44(video),46(plugdev),60(games),100(users),101(input),108(netdev),121(render),997(gpio),998(i2c),999(spi)
dietpi in DietPi in ~ ✦ ❯ touch /tmp/4947
I just don’t understand were the error comes from. What is meant, the /tpm of the host or /tmp inside the container?
Can someone point me to the right direction.
TIA Micha
