I would like to create a drill down in my bar chart, so I could click on the individual bars, and be sent to a new site with a variable set to the name of the bar;
Here’s an image of the bar graph. What I want is to be able to insert for example node-test-100 in a link when I click on the far left bar. Is this possible?
quick example of use from me
in my case i have to do it with override option to be able to target specific table column “id” reference of ticket. i use it in link to redirect to ticketing tool
no no my example is with Bar chart, did you find the option ?
as you can see on my screenshot i was able to make the link you can see it in the hover mouse information.
maybe that’s why i ask , you can see it on your profile button on bottom left.
would you try with a simpler example ? you can use dummy data source like me “TestData DB” , this is a special data source (built-in) made for that.
