Dynamically adjust values to currently selected range
Hey :slightly_smiling_face:
I have this query right now:
from(bucket: "iobroker")
  |> filter(fn: (r) => r["_measurement"] == "sourceanalytix.0.shelly__1__shellyplus1pm#7c87ce64d6d0#1__Relay0__Energy.cumulativeReading")
  |> filter(fn: (r) => r["_field"] == "value")
  |> aggregateWindow(every: 30m, fn:last)
  |> difference()
  |> yield(name: "mean")
It will give me a bar chart with the produced kwh in a 30 minute interval.
This works very well in a max 7 day range. But what if I want to change the dashboard to let’s say 6 months? Is there any way to dynamically adjust the “every: 30m” value to the current range?
I have really no idea yet how the flux language works… But I could think of something like this:
if range() <= 7d then
else
aggregateWindow(every: 1d, fn:last)
Is that possible somehow?
hello,
Where would you be changing this 6 months range?
With the time range picker of my dashboard
This is how it will look with a selected range of 7 days (Every: 30m):
I want the query to automatically switch to something like that (Every: 1d):
what if they select date ranges from here?
Doesn’t matter.
I want to adjust my query as soon as the selected range is >7 days :smiley:
:laughing:
so let’s start with what the doc says and also those grafana global variables
color = if code == 0 then "green" else if code == 1 then "yellow" else "red"
Now let’s try capturing the time values from grafana in flux
Not sure how you can capture global variales such as $__timeFilter :frowning:
BUt you can capture your own variables
import "array"
filter = "$boojie"
a = [
    "1",
    "2",
    "3",
    "4",
    filter,
b = a |> array.map(fn: (x) => ({_value: x}))
array.from(rows: b)
I came up with something like that now:
timestart = uint(v: v.timeRangeStart)
timestop = uint(v: v.timeRangeStop)
duration = duration(v:timestop - timestart)
  |> aggregateWindow(every: if int(v:duration) <= int(v:2d) then  30m else if int(v:duration) <= int(v:7d) then 1h else 1d , fn:last)
  |> difference()
  |> yield(name: "mean")
Works perfectly :heart_eyes:
Maybe I am able to help someone else with these problems:
First error was:
time is not Subtractable
Solution:
You have to convert the timestamp value to unix time with the uint() function
Second error:
unsupported binary expression duration < duration
Solution:
To compare two durations (e.g. 1d < 2d) you have to convert them to a numeric value first.
int(v:1d) < int(v:2d)
Great, thank you for this!
I “simplified” it further by computing a window size that always gains 800 records:
  |> aggregateWindow(every: duration(v:(uint(v: v.timeRangeStop) - uint(v: v.timeRangeStart))/uint(v: 800)), fn:last)
  |> yield(name: "mean")
