How do I set it up so that each panel in the dashboard has its own timeline. I can’t get it to run. all panels are always the same. this is driving me insane
Hi @petapan,
Thanks for opening this post.
Can you explain your use case in a bit more detail?
To me, it sounds like you need Rows to separate several panels from each other.
Hi @petapan,
Different time ranges for each panel can be achieved by specifying “Relative time” in Query Options like on picture:
Result:
Note: All 5 panels show same metric but in different time ranges. By changing global dashboard time (in upper right corner) only time range of 1st panel would change.
Hope this helps.
Best regards,
ldrascic
