Enable using Environment variables in contact points provisioned files
Similarly to datasources files, it would be great if it was possible to use environment variables in the files use to provision contact points.
Cheers
Hi @davidvgl,
Did you had already a look at our official Documentation for provisioning?
There is a section defined for Contact Points.
If this is not what you looking for then can you please explain a bit in more detail as what you want to achieve and what are your expectations?
Can confirm that using Environment variables when provisioning Contact Points is not working.
Have opened an issue here Environment variables not working when provisioning Contact Points · Issue #56437 · grafana/grafana · GitHub
Please go in and like it to get attention to it
thanks for your answer and thanks for you issue Daniel. It was exactly my point.
I see it is going to be fix in 9.1.7 and 9.2.0
This ticket can be close.
