Error Parsing Syslog Stream
Expected behavior
Log messages to get forwarded to Grafana / Loki
Actual behavior
Error message:
Apr 24 14:44:50 grafana promtail-linux-amd64[200904]: level=warn ts=2023-04-24T14:44:50.3438799Z caller=syslogtarget.go:105 msg=“error parsing syslog stream” err=“expecting an app-name (from 1 to max 48 US-ASCII characters) or a nil value [col 54]”
All other network devices work properly.
Steps to reproduce the behavior
I am forwarding Meraki logs to Rsyslog to get scraped by Promtail and forwarded into Grafana/Loki. However when forwardiing this is the error I receive.
Environment
  • Grafana Version: 9.4.7
  • rsyslog version: 8.2112.0
  • platform: Ubuntu 22.04.2
Welcome
Could you please post sample syslog couple of line, obfuscate any sensitive data you might have?
rsyslog.conf:
/etc/rsyslog.conf configuration file for rsyslog
Default logging rules can be found in /etc/rsyslog.d/50-default.conf
MODULES
module(load=“imuxsock”) # provides support for local system logging
#module(load=“immark”) # provides --MARK-- message capability
provides UDP syslog reception
#module(load=“imudp”)
#input(type=“imudp” port=“514”)
$ModLoad imudp
$UDPServerRun
provides TCP syslog reception
#module(load=“imtcp”)
#input(type=“imtcp” port=“514”)
provides kernel logging support and enable non-kernel klog messages
module(load=“imklog” permitnonkernelfacility=“on”)
GLOBAL DIRECTIVES
Use traditional timestamp format.
To enable high precision timestamps, comment out the following line.
$ActionFileDefaultTemplate RSYSLOG_TraditionalFileFormat
Filter duplicated messages
$RepeatedMsgReduction on
Set the default permissions for all log files.
$FileOwner syslog
$FileGroup adm
$FileCreateMode 0640
$DirCreateMode 0755
$Umask 0022
$PrivDropToUser syslog
$PrivDropToGroup syslog
Where to place spool and state files
$WorkDirectory /var/spool/rsyslog
Include all config files in /etc/rsyslog.d/
$IncludeConfig /etc/rsyslog.d/*.conf
$template remote-incoming-logs, "/var/log/logs.log
. ?remote-incoming-logs
STOP
Promtail Config:
action(type=“omfwd” Target=“localhost” Port=“1514” Protocol=“tcp” Template=“RSYSLOG_SyslogProtocol23Format”)
RSyslog Documentation - rsyslog
input(type=“imudp” port=“514” ruleset=“remote”)
input(type=“imtcp” port=“514” ruleset=“remote”)
Great. You provided everything except what I asked. :laughing:
Please provide us a sample actual syslog data from your log file
Oops!! Sorry.
1379967288.409907239 MS220_8P events port 3 status changed from 100fdx to down
1380653443.857790533 MR18 events type=association radio=‘0’ vap=‘1’ channel=‘6’ rssi=‘23’ aid=‘1813578850’
