Hello! I have error when try get log from Grafana:
level=error ts=2022-11-18T16:42:36.297541797Z caller=retry.go:73 org_id=fake msg=“error processing request” try=1 err=“rpc error: code = Code(500) desc = empty ring\n”
ts=2022-11-18T16:42:36.297917582Z caller=spanlogger.go:80 user=fake method=query.Label level=info org_id=fake latency=fast query_type=labels length=1h0m0.001s duration=7.533µs status=500 label= throughput=0B total_bytes=0B total_entries=0
My docker-compose.yml
#version: "3.8"
services:
init:
image: grafana/loki:2.6.1
user: root
entrypoint:
- "chown"
- "10001:10001"
- "/loki"
volumes:
- ./loki:/loki
networks:
- loki
cassandra:
image: bitnami/cassandra:3.11.11
restart: always
ports:
- "9042:9042"
volumes:
- cassandra:/bitnami
healthcheck:
test: ["CMD", "cqlsh", "-u", "cassandra", "-p", "cassandra", "-e", "SELECT table_name FROM system_schema.tables WHERE keyspace_name='loki';"]
interval: 5s
timeout: 5s
retries: 10
environment:
CASSANDRA_USER: cassandra
CASSANDRA_PASSWORD: cassandra
CASSANDRA_CLUSTER_NAME: loki
CASSANDRA_DATACENTER: dc1
networks:
loki:
aliases:
- cassandra
log-generator:
image: mingrammer/flog
restart: always
command:
- --loop
- --format=json
- --number=10
- --delay=100ms
- --output=/var/log/generated-logs.txt
- --overwrite
- --type=log
depends_on:
promtail:
condition: service_started
volumes:
- ./loki/:/var/log/
promtail:
image: grafana/promtail:2.6.1
restart: always
volumes:
- ./loki/:/var/log/
- ./config:/etc/promtail/
ports:
- "9080:9080"
command: -config.file=/etc/promtail/promtail.yaml
depends_on:
loki-gateway:
loki-frontend:
loki-read:
loki-write:
networks:
loki:
aliases:
- promtail
minio:
image: minio/minio
restart: always
entrypoint:
- sh
- -euc
mkdir -p /data/loki-data && \
mkdir -p /data/loki-ruler &&
minio server /data
environment:
- MINIO_ACCESS_KEY=loki
- MINIO_SECRET_KEY=supersecret
- MINIO_PROMETHEUS_AUTH_TYPE=public
- MINIO_UPDATE=off
ports:
- "9000:9000"
volumes:
- ./.data/minio:/data
networks:
loki:
aliases:
- minio
loki-gateway:
image: nginx:1.19
restart: always
volumes:
- ./config/nginx.conf:/etc/nginx/nginx.conf
ports:
- "8080:80"
- "3100"
networks:
loki:
aliases:
- loki-gateway
depends_on:
loki-frontend:
loki-read:
loki-write:
loki-frontend:
restart: always
volumes:
- ./config:/etc/loki/
ports:
- "3100"
command: "-config.file=/etc/loki/loki.yaml -target=query-frontend -frontend.downstream-url=http://loki-read:3100"
networks:
loki:
aliases:
- loki-frontend
deploy:
mode: replicated
replicas: 1
depends_on:
cassandra:
condition: service_healthy
loki-read:
restart: always
volumes:
ports:
- "3100"
- "7946"
command: "-config.file=/etc/loki/loki.yaml -target=read"
networks:
loki:
aliases:
- loki-read
deploy:
mode: replicated
replicas: 1
depends_on:
cassandra:
loki-write:
restart: always
volumes:
ports:
- "3100"
- "7946"
command: "-config.file=/etc/loki/loki.yaml -target=write"
networks:
loki:
aliases:
- loki-write
deploy:
mode: replicated
replicas: 1
depends_on:
cassandra:
grafana:
image: grafana/grafana:9.1.6
restart: always
ports:
- "3000:3000"
environment:
GF_AUTH_ANONYMOUS_ENABLED: "true"
GF_AUTH_DISABLE_LOGIN_FORM: "true"
GF_AUTH_ANONYMOUS_ORG_ROLE: "Admin"
volumes:
- ./config/datasources.yaml:/etc/grafana/provisioning/datasources/datasources.yml
- grafana:/var/lib/grafana
networks:
- loki
volumes:
cassandra:
grafana:
networks:
loki:
driver: bridge
My loki.yaml
auth_enabled: false
#target: ingester, querier, query-scheduler, query-frontend, ruler, table-manager, read, write.
target: table_manager
server:
http_listen_address: 0.0.0.0
grpc_listen_address: 0.0.0.0
http_listen_port: 3100
http_server_read_timeout: 180s
http_server_write_timeout: 180s
common:
path_prefix: /loki/
storage:
filesystem:
chunks_directory: /loki/chunks
rules_directory: /loki/rules
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
#memberlist:
# join_members: ["loki-read", "loki-write", "cassandra", "ingester"]
# dead_node_reclaim_time: 30s
# gossip_to_dead_nodes_time: 15s
# left_ingesters_timeout: 30s
# bind_addr: ['0.0.0.0']
# bind_port: 7946
# gossip_interval: 2s
ingester:
lifecycler:
join_after: 10s
observe_period: 5s
ring:
kvstore:
store: inmemory
final_sleep: 0s
chunk_idle_period: 1h
wal:
enabled: true
dir: /loki/wal
max_chunk_age: 1h
chunk_target_size: 1048576
chunk_retain_period: 30s
max_transfer_retries: 0
schema_config:
configs:
store: cassandra
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
storage_config:
cassandra:
username: cassandra
password: cassandra
addresses: cassandra
consistency: ONE
auth: true
keyspace: loki
timeout: 20s
connect_timeout: 20s
filesystem:
limits_config:
enforce_metric_name: false
reject_old_samples: true
reject_old_samples_max_age: 168h
ingestion_rate_mb: 500
ingestion_burst_size_mb: 500
max_cache_freshness_per_query: '10m'
max_query_series: 100000
max_query_parallelism: 16
split_queries_by_interval: 60m
chunk_store_config:
max_look_back_period: 720h
table_manager:
retention_deletes_enabled: true
retention_period: 720h
query_range:
align_queries_with_step: true
max_retries: 10
cache_results: true
parallelise_shardable_queries: true
frontend:
log_queries_longer_than: 5s
compress_responses: true
query_scheduler:
max_outstanding_requests_per_tenant: 1024
querier:
engine:
query_ingesters_within: 2h
query_timeout: 1200s
#compactor:
# working_directory: /tmp/compactor
# shared_store: s3
ruler:
storage:
type: local
local:
ring:
kvstore:
store: inmemory
rule_path: /loki/scratch
How fix this issue ?
