- What Grafana version and what operating system are you using?
Grafana v9.1.6 on a Debian VM and Grafana v9.2.2 in a docker container
- What are you trying to achieve?
I want to import a dashboard from my locally running grafana instance into a new docker container running the latest version of the grafana/grafana image.
- How are you trying to achieve it?
Copying the JSON model of my Dashboard and pasting it to the “import” tab on my grafana container.
- What happened?
Error: Internal Server Error: Check the Grafana Server Logs for the detailed error message
The dashboard was imported with the panels having the right size and names, but without any queries. I also can’t edit the queries, I am getting an internal server error when trying to edit those. The error messages stating that “a dashboard with that name already exists” are popping up as soon as I click the import button without the dashboard actually existing before pressing the import button.
In my logs, I got this message:
logger=context userId=1 orgId=1 uname=admin t=2022-10-27T08:05:59.758454759Z level=error msg="Request error" error="assignment to entry in nil map" stack="/usr/local/go/src/runtime/map_faststr.go:205 (0x412e2b)
/drone/src/pkg/services/libraryelements/database.go:65 (0x1e65297)
/drone/src/pkg/services/libraryelements/database.go:136 (0x1e65abf)
/drone/src/pkg/services/libraryelements/libraryelements.go:47 (0x1e6ac23)
/drone/src/pkg/services/librarypanels/librarypanels.go:317 (0x203cb87)
/drone/src/pkg/services/librarypanels/librarypanels.go:262 (0x203c297)
/drone/src/pkg/services/dashboardimport/service/service.go:104 (0x27d518b)
/drone/src/pkg/services/dashboardimport/api/api.go:77 (0x27d38ab)
/drone/src/pkg/api/routing/routing.go:17 (0x14cb727)
/drone/src/pkg/api/response/web_hack.go:40 (0x10561a7)
/usr/local/go/src/net/http/server.go:2109 (0x6bf687)
/drone/src/pkg/web/macaron.go:135 (0xef977b)
/drone/src/pkg/web/macaron.go:141 (0xef981f)
/drone/src/pkg/middleware/csp.go:22 (0x14c3243)
/drone/src/pkg/services/contexthandler/contexthandler.go:175 (0x14affa3)
/drone/src/pkg/web/render.go:44 (0xefa2c3)
/drone/src/pkg/middleware/csrf/csrf.go:64 (0x1ef72df)
/drone/src/pkg/middleware/recovery.go:171 (0x14c650b)
/drone/src/pkg/middleware/logger.go:40 (0x14c4203)
/drone/src/pkg/middleware/request_metrics.go:58 (0x14c7257)
/drone/src/pkg/middleware/request_tracing.go:88 (0x14c8803)
/drone/src/pkg/web/context.go:44 (0xef8327)
/drone/src/pkg/web/router.go:155 (0xefb67f)
/drone/src/pkg/web/router.go:211 (0xefc24f)
/drone/src/pkg/web/macaron.go:161 (0xef9bfb)
/usr/local/go/src/net/http/server.go:2947 (0x6c25bb)
/usr/local/go/src/net/http/server.go:1991 (0x6be473)
/usr/local/go/src/runtime/asm_arm64.s:1172 (0x46dda3)
- What did you expect to happen?
Importing the dashboard without an error.
- Did you follow any online instructions? If so, what is the URL?
I already searched for online help, but couldn’t find anything similar.
