Error when threshold fails
Hi, I am spawning k6 process using execSync() in node js , and when a threshold fails, all the steps are shown as failed in the terminal as below as ‘command failed’:
Is there any way to avoid that, and just show the error message about the threshold failure ?
Hi @Fabien,
I don’t know if I understood correctly, but it is possible via setting abortOnFail to false, it is false by default:
