Hello everybody,
I use CentOS 8 and would like to create a new plugin.
I proceeded according to the tutorial:
Grafana 7.0 -> Ok
NodeJS 12.x -> Ok
yarn -> Ok
python -> Ok
In the plugin directory, create a plugin from template using the plugin:create command:
npx @grafana/toolkit plugin:create my-plugin
Unable to save binary /root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/vendor/linux-x64-64 : { Error: EACCES: permission denied, mkdir ‘/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/vendor’
at Object.mkdirSync (fs.js:757:3)
at sync (/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/mkdirp/index.js:72:13)
at Function.sync (/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/mkdirp/index.js:78:24)
at checkAndDownloadBinary (/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/scripts/install.js:114:11)
at Object. (/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/scripts/install.js:157:1)
at Module._compile (internal/modules/cjs/loader.js:778:30)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
at Module.load (internal/modules/cjs/loader.js:653:32)
at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
at Function.Module._load (internal/modules/cjs/loader.js:585:3)
errno: -13,
syscall: ‘mkdir’,
code: ‘EACCES’,
path:
‘/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/vendor’ }
gyp info it worked if it ends with ok
gyp verb cli [ ‘/usr/bin/node’,
gyp verb cli ‘/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-gyp/bin/node-gyp.js’,
gyp verb cli ‘rebuild’,
gyp verb cli ‘–verbose’,
gyp verb cli ‘–libsass_ext=’,
gyp verb cli ‘–libsass_cflags=’,
gyp verb cli ‘–libsass_ldflags=’,
gyp verb cli ‘–libsass_library=’ ]
gyp info using node-gyp@3.8.0
gyp info using node@10.21.0 | linux | x64
gyp verb command rebuild []
gyp verb command clean []
gyp verb clean removing “build” directory
gyp verb command configure []
gyp verb check python checking for Python executable “python2” in the PATH
gyp verb which
succeeded python2 /usr/bin/python2
gyp verb check python version /usr/bin/python2 -c "import sys; print "2.7.17 gyp verb check python version .%s.%s" % sys.version_info[:3];"
returned: %j
gyp verb get node dir no --target version specified, falling back to host node version: 10.21.0
gyp verb command install [ ‘10.21.0’ ]
gyp verb install input version string “10.21.0”
gyp verb install installing version: 10.21.0
gyp verb install --ensure was passed, so won’t reinstall if already installed
gyp verb install version not already installed, continuing with install 10.21.0
gyp verb ensuring nodedir is created /root/.node-gyp/10.21.0
gyp WARN EACCES user “root” does not have permission to access the dev dir “/root/.node-gyp/10.21.0”
gyp WARN EACCES attempting to reinstall using temporary dev dir “/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/.node-gyp”
gyp verb tmpdir == cwd automatically will remove dev files after to save disk space
gyp verb command install [ ‘–node_gyp_internal_noretry’, ‘10.21.0’ ]
gyp verb ensuring nodedir is created /root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/.node-gyp/10.21.0
gyp WARN install got an error, rolling back install
gyp verb command remove [ ‘10.21.0’ ]
gyp verb remove using node-gyp dir: /root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/.node-gyp
gyp verb remove removing target version: 10.21.0
gyp verb remove removing development files for version: 10.21.0
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir ‘/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass/.node-gyp’
gyp ERR! System Linux 4.18.0-193.14.2.el8_2.x86_64
gyp ERR! command “/usr/bin/node” “/root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-gyp/bin/node-gyp.js” “rebuild” “–verbose” “–libsass_ext=” “–libsass_cflags=” “–libsass_ldflags=” “–libsass_library=”
gyp ERR! cwd /root/.npm/_npx/1468239/lib/node_modules/@grafana/toolkit/node_modules/node-sass
gyp ERR! node -v v10.21.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
Build failed with error code: 1
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-sass@4.14.1 postinstall: node scripts/build.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-sass@4.14.1 postinstall script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2020-08-18T18_05_05_712Z-debug.log
Die Installation von @grafana/toolkit@latest ist mit dem Code 1 fehlgeschlagen
Can someone help me???
