Existing connection was forcibly closed by the remote host
Hi Team,
I have the below code which is working fine in headless mode till clicking on the CONFIGURATION link. But once I click on the CONFIGURATION link I would like to.
  1. Select ‘Server Template’
  2. Enter ‘Discovery Document URL’
  3. Click on ‘Save’
Could you please help on the same.
import { chromium } from 'k6/x/browser';
import { options, openidconnect_url, discovery_document_url, userName, password } from "./common_openid.js";
export {options};
export default function () {
  const browser = chromium.launch({
    headless: true,
    slowMo: '1s',
  const context = browser.newContext();
  const page = context.newPage();
  // 01. Go to the openidconnect landing page and click on CONFIGURATION
  page.goto('https://openidconnect.net/', { waitUntil: 'networkidle' }).then(() => {
    page.screenshot({ path: 'screenshots/01_screenshot.png' });
    page.waitForSelector('button[class="playground-header-config btn btn-link"]');
    return page.click('button[class="playground-header-config btn btn-link"]');
  }).then(() => {
    page.screenshot({ path: 'screenshots/02_screenshot.png' });
    page.selectOption("select[name='server']", "Custom");
    page.type("input[placeholder='https://my-oidc.com/.well-known/openid-configuration']", "some test url");
    page.click('button[class="code-box-btn is-alt"]');
    page.screenshot({ path: 'screenshots/03_screenshot.png' });
  }).finally(() => {
    page.close();
    browser.close();
Hi @vishvambruth.javagal,
Since the click action returns a promise, we should wait for it to return (like below):
  }).then(() => {
    return page.click('button[class="code-box-btn is-alt"]'); // <-- this
  }).then(() => {                                             // <-- this
  }).finally(() => {
    page.close();
    browser.close();
I tried this, and it took three screenshots.
But its not selecting the value from dropdown and typing the required text in the text box.
Any thing wrong with the below code:
The click action returns a promise (as I explained above), the last code you shared doesn’t handle that, but the last one I shared does.
Besides that, the value in the dropdown is "custom" (with a lowercase c, not Custom). Please change the selectOption as below:
page.selectOption("select[name='server']", "custom");
And please don’t forget handling the promise as I explained in my previous comments.
Hi @inanc,
Thanks, I have written the below script and now its selecting the dropdown value. But after selecting the dropdown value Im trying to set the ‘Discovery Document URL’ with some URL and its failing to type in. Could you please take a look.
Note: The issue persists when we try to type long URL. Typing short URLs is working fine.
Unable to type: https://my-oidc.com/.well-known/openid-configuration
Able to type: https://my-oidc.com/
    headless: true,
    slowMo: '1s',
  }).then(() => {
    page.waitForSelector("select[name='server']");
    return page.selectOption("select[name='server']", "custom");
  }).then(() => {
    page.waitForSelector("input[placeholder='https://my-oidc.com/.well-known/openid-configuration']");
    return page.click("input[placeholder='https://my-oidc.com/.well-known/openid-configuration']");
  }).then(() => {
    page.screenshot({ path: 'screenshots/04_screenshot.png' });
    page.type("input[placeholder='https://my-oidc.com/.well-known/openid-configuration']", 'https://my-oidc.com/.well-known/openid-configuration');
    page.screenshot({ path: 'screenshots/05_screenshot.png' });
  }).finally(() => {
    page.close();
    browser.close();
PS C:\K6\xk6-browser> ./xk6-browser run openid_test.js
  / __________ \  |__| \__\ \_____/ .io
  execution: local
     script: openid_test.js
     output: -
  scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
           * default: 1 iterations for each of 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
ERRO[0004] Failed to load resource: the server responded with a status of 403 ()  browser_source=network line_number=0 source=browser stacktrace="<nil>" url="https://alb.reddit.com/rp.gif?ts=1666712168171&id=t2_16vcix&event=PageVisit&m.itemCount=&m.value=&m.valueDecimal=&m.currency=&m.transactionId=&m.customEventName=&m.products=&uuid=009f7f87-f960-4cb5-a242-a855b9ac9fca&aaid=&em=&external_id=&idfa=&integration=reddit&opt_out=0&sh=1280&sw=720&v=rdt_02c59ad6"
ERRO[0030] communicating with browser: read tcp 127.0.0.1:51237->127.0.0.1:51236: wsarecv: An existing connection was forcibly
closed by the remote host.  category=cdp elapsed="0 ms" goroutine=61
ERRO[0030] Uncaught (in promise) GoError: typing "https://my-oidc.com/.well-known/openid-configuration" in "input[placeholder='https://my-oidc.com/.well-known/openid-configuration']": pressing key: dispatching key event up: read tcp 127.0.0.1:51237->127.0.0.1:51236: wsarecv: An existing connection was forcibly closed by the remote host.: GoError
        at reflect.methodValueCall (native)
        at file:///C:/K6/xk6-browser/openid_test.js:26:4(11)
        at native
  executor=per-vu-iterations scenario=default
ERRO[0030] process with PID 141024 unexpectedly ended: exit status 1  category=browser elapsed="33 ms" goroutine=41
running (00m30.1s), 0/1 VUs, 1 complete and 0 interrupted iterations
default ✓ [======================================] 1 VUs  00m30.1s/10m0s  1/1 iters, 1 per VU
     browser_dom_content_loaded.......: avg=227.41ms min=37µs    med=1.94ms   max=5.61s  p(90)=6.68ms   p(95)=20.65ms
     browser_first_contentful_paint...: avg=5.61s    min=5.61s   med=5.61s    max=5.61s  p(90)=5.61s    p(95)=5.61s
     browser_first_meaningful_paint...: avg=5.61s    min=5.61s   med=5.61s    max=5.61s  p(90)=5.61s    p(95)=5.61s
     browser_first_paint..............: avg=5.61s    min=5.61s   med=5.61s    max=5.61s  p(90)=5.61s    p(95)=5.61s
     browser_loaded...................: avg=569.07ms min=221µs   med=3.31ms   max=6.64s  p(90)=510.02ms p(95)=2.35s
     data_received....................: 3.1 MB 103 kB/s
     data_sent........................: 48 kB  1.6 kB/s
     http_req_connecting..............: avg=63.05ms  min=0s      med=20ms     max=902ms  p(90)=97.9ms   p(95)=323.34ms
     http_req_duration................: avg=297.39ms min=13.92ms med=220.28ms max=1.52s  p(90)=521.95ms p(95)=1.03s
     http_req_receiving...............: avg=130.78ms min=12ms    med=54.5ms   max=1.03s  p(90)=248ms    p(95)=286.44ms
     http_req_sending.................: avg=0s       min=0s      med=0s       max=0s     p(90)=0s       p(95)=0s
     http_req_tls_handshaking.........: avg=40.95ms  min=0s      med=16.5ms   max=602ms  p(90)=69.9ms   p(95)=186.59ms
     http_reqs........................: 112    3.726465/s
     iteration_duration...............: avg=30.05s   min=30.05s  med=30.05s   max=30.05s p(90)=30.05s   p(95)=30.05s
     iterations.......................: 1      0.033272/s
     vus..............................: 1      min=1      max=1
     vus_max..........................: 1      min=1      max=1
I tried a slightly modified script on my Mac, and it took 5 screenshots. The selectOption action does not return a promise. The modified script looks as the following:
    headless: true,
    slowMo: '1s',
  }).then(() => {
    page.selectOption("select[name='server']", "custom"); // <-------------------
  }).then(() => {
  }).finally(() => {
    page.close();
    browser.close();
@inanc, I tried your below script on my windows machine and its failing. Please find the terminal logs below.
    headless: true,
    slowMo: '1s',
  }).then(() => {
  }).then(() => {
  }).finally(() => {
    page.close();
    browser.close();
PS C:\K6\xk6-browser> ./xk6-browser run .\openid_test.js
  execution: local
     script: .\openid_test.js
     output: -
ERRO[0005] Failed to load resource: the server responded with a status of 403 ()  browser_source=network line_number=0 source=browser stacktrace="<nil>" url="https://alb.reddit.com/rp.gif?ts=1666863081346&id=t2_16vcix&event=PageVisit&m.itemCount=&m.value=&m.valueDecimal=&m.currency=&m.transactionId=&m.customEventName=&m.products=&uuid=36505dcd-eb5b-4918-8f8e-6567c2a00c0d&aaid=&em=&external_id=&idfa=&integration=reddit&opt_out=0&sh=1280&sw=720&v=rdt_02c59ad6"
ERRO[0030] communicating with browser: read tcp 127.0.0.1:49743->127.0.0.1:49742: wsarecv: An existing connection was forcibly
closed by the remote host.  category=cdp elapsed="0 ms" goroutine=46
ERRO[0030] process with PID 79600 unexpectedly ended: exit status 1  category=browser elapsed="34 ms" goroutine=67
ERRO[0030] Uncaught (in promise) GoError: typing "https://my-oidc.com/.well-known/openid-configuration" in "input[placeholder='https://my-oidc.com/.well-known/openid-configuration']": pressing key: dispatching key event up: read tcp 127.0.0.1:49743->127.0.0.1:49742: wsarecv: An existing connection was forcibly closed by the remote host.: GoError
        at file:///C:/K6/xk6-browser/openid_test.js:25:4(11)
        at native
     browser_dom_content_loaded.......: avg=212.07ms min=34µs    med=2.14ms   max=6.01s  p(90)=15.77ms  p(95)=33.81ms
     browser_first_contentful_paint...: avg=6s       min=6s      med=6s       max=6s     p(90)=6s       p(95)=6s
     browser_first_meaningful_paint...: avg=6s       min=6s      med=6s       max=6s     p(90)=6s       p(95)=6s
     browser_first_paint..............: avg=6s       min=6s      med=6s       max=6s     p(90)=6s       p(95)=6s
     browser_loaded...................: avg=558.46ms min=235µs   med=5.85ms   max=7.11s  p(90)=645.84ms p(95)=1.97s
     data_received....................: 3.1 MB 104 kB/s
     data_sent........................: 51 kB  1.7 kB/s
     http_req_connecting..............: avg=74.64ms  min=0s      med=34ms     max=891ms  p(90)=142.8ms  p(95)=446.59ms
     http_req_duration................: avg=331.95ms min=11.75ms med=209.36ms max=2.74s  p(90)=615.42ms p(95)=1.03s
     http_req_receiving...............: avg=159.15ms min=8ms     med=84ms     max=2.14s  p(90)=276.8ms  p(95)=326.19ms
     http_req_sending.................: avg=8.54µs   min=0s      med=0s       max=1ms    p(90)=0s       p(95)=0s
     http_req_tls_handshaking.........: avg=50.15ms  min=0s      med=21ms     max=597ms  p(90)=104.4ms  p(95)=226.39ms
     http_reqs........................: 117    3.889821/s
     iteration_duration...............: avg=30.07s   min=30.07s  med=30.07s   max=30.07s p(90)=30.07s   p(95)=30.07s
     iterations.......................: 1      0.033246/s
That’s interesting. By the way, you don’t have to click on the input box (The type action already does that). So run with the following script:
    headless: true,
    slowMo: '1s',
  }).then(() => {
  }).finally(() => {
    page.close();
    browser.close();
Could you run the script above with the following command and send us the debug log?
XK6_BROWSER_LOG=trace ./xk6-browser run -q .\openid_test.js
Hi @inanc, The above script again failing. Please find the debug log below:
DEBU[0046] sid:EEEA4F6FD40EBCF56D3DB3E2C6F3CD74 tid:D816EA9BC420C4BCBB67E3D208279537  category="FrameSession:initEvents:go:session.done" elapsed="0 ms" goroutine=89
WARN[0046] url:https://snap.licdn.com/li.lms-analytics/insight.min.js method:GET err:fetching response body: closing communication with browser: websocket: close 1001 (going away)  category="Response:bodySize:fetchBody" elapsed="0 ms" goroutine=170
DEBU[0046] sid:EEEA4F6FD40EBCF56D3DB3E2C6F3CD74 tid:D816EA9BC420C4BCBB67E3D208279537  category="Session:readLoop:<-s.done" elapsed="1 ms" goroutine=98
DEBU[0046] sid:BB4F2ABF4115DBD650F6A1A7285D9571 tid:D794F84E01C8389A7D9DC6D8A9E5F244 fid:D794F84E01C8389A7D9DC6D8A9E5F244 event:InteractiveTime eventTime:"2022-10-27 16:28:31.015153 +0530 IST m=+11.246753801"  category="FrameSession:onPageLifecycle" elapsed="1 ms" goroutine=111
DEBU[0046] sid:BB4F2ABF4115DBD650F6A1A7285D9571 tid:D794F84E01C8389A7D9DC6D8A9E5F244  category="Session:readLoop:<-s.done" elapsed="0 ms" goroutine=102
DEBU[0046]                                               category="Browser:initEvents:EventConnectionClose" elapsed="1 ms" goroutine=82
DEBU[0046] sid:BB4F2ABF4115DBD650F6A1A7285D9571 tid:D794F84E01C8389A7D9DC6D8A9E5F244 method:"Network.getResponseBody"  category="Session:Execute:<-evCancelCtx.Done():return" elapsed="0 ms" goroutine=1587
DEBU[0046] sid:EEEA4F6FD40EBCF56D3DB3E2C6F3CD74 tid:D816EA9BC420C4BCBB67E3D208279537  category="NewFrameSession:initEvents:go:return" elapsed="0 ms" goroutine=89
DEBU[0046] fmid:2 rurl:https://snap.licdn.com/li.lms-analytics/insight.min.js  category="FrameManager:requestFinished" elapsed="1 ms" goroutine=170
DEBU[0046] sid:BB4F2ABF4115DBD650F6A1A7285D9571 tid:D794F84E01C8389A7D9DC6D8A9E5F244  category="FrameSession:initEvents:go:session.done" elapsed="0 ms" goroutine=111
DEBU[0046] ctx err: <nil>                                category="Browser:initEvents:defer" elapsed="1 ms" goroutine=82
DEBU[0046] fid:D794F84E01C8389A7D9DC6D8A9E5F244 furl:"https://openidconnect.net/" rid:91616.19  category="Frame:deleteRequest" elapsed="0 ms" goroutine=170
DEBU[0046] sid:BB4F2ABF4115DBD650F6A1A7285D9571 tid:D794F84E01C8389A7D9DC6D8A9E5F244  category="NewFrameSession:initEvents:go:return" elapsed="0 ms" goroutine=111
DEBU[0046] sid:BB4F2ABF4115DBD650F6A1A7285D9571          category="Page:Close" elapsed="1 ms" goroutine=28
DEBU[0046] bctxid:9156F77804C05979AF5457F8A51A6E70       category="BrowserContext:Close" elapsed="0 ms" goroutine=28
DEBU[0046] bctxid:9156F77804C05979AF5457F8A51A6E70       category="Browser:disposeContext" elapsed="0 ms" goroutine=28
DEBU[0046] wsURL:"ws://127.0.0.1:56028/devtools/browser/2e492d12-e6a6-4798-9918-e8b989674927" method:"Target.disposeBrowserContext"  category="connection:Execute" elapsed="2 ms" goroutine=28
DEBU[0046] wsURL:"ws://127.0.0.1:56028/devtools/browser/2e492d12-e6a6-4798-9918-e8b989674927" sid:  category="Connection:send:<-c.done" elapsed="0 ms" goroutine=28
DEBU[0046] wsURL:"ws://127.0.0.1:56028/devtools/browser/2e492d12-e6a6-4798-9918-e8b989674927" err:context canceled  category="connection:Execute:<-evCancelCtx.Done()" elapsed="1 ms" goroutine=1562
DEBU[0046]                                               category="Browser:Close" elapsed="0 ms" goroutine=28
DEBU[0046]                                               category="Browser:GracefulClose" elapsed="1 ms" goroutine=28
DEBU[0046] wsURL:"ws://127.0.0.1:56028/devtools/browser/2e492d12-e6a6-4798-9918-e8b989674927" method:"Browser.close"  category="connection:Execute" elapsed="0 ms" goroutine=28
DEBU[0046] wsURL:"ws://127.0.0.1:56028/devtools/browser/2e492d12-e6a6-4798-9918-e8b989674927" sid: err:context
canceled  category="Connection:send:<-ctx.Done" elapsed="0 ms" goroutine=28
DEBU[0046] wsURL:"ws://127.0.0.1:56028/devtools/browser/2e492d12-e6a6-4798-9918-e8b989674927" code:1001  category="connection:Close" elapsed="1 ms" goroutine=28
DEBU[0046] wsURL:"ws://127.0.0.1:56028/devtools/browser/2e492d12-e6a6-4798-9918-e8b989674927" err:context canceled  category="connection:Execute:<-evCancelCtx.Done()" elapsed="0 ms" goroutine=1590
DEBU[0046] code:1001                                     category="Connection:close" elapsed="1 ms" goroutine=28
ERRO[0046] Uncaught (in promise) navigating to "https://openidconnect.net/": timed out after 30s  executor=per-vu-iterations scenario=default
DEBU[0046] Regular duration is done, waiting for iterations to gracefully finish  executor=per-vu-iterations gracefulStop=30s scenario=default
DEBU[0046] Executor finished successfully                executor=default startTime=0s type=per-vu-iterations
DEBU[0046] Running teardown()                            phase=local-execution-scheduler-run
DEBU[0046] Metrics emission of VUs and VUsMax metrics stopped
DEBU[0046] Execution scheduler terminated                component=engine error="<nil>"
DEBU[0046] Processing metrics and thresholds after the test run has ended...  component=engine
DEBU[0046] Stopping...                                   component=metrics-engine-ingester
DEBU[0046] run: execution scheduler terminated           component=engine
DEBU[0046] Stopped!                                      component=metrics-engine-ingester
DEBU[0046] Engine run terminated cleanly
DEBU[0046] Engine: Thresholds terminated                 component=engine
     browser_dom_content_loaded.......: avg=74.97ms  min=52µs    med=4.2ms    max=1.74s  p(90)=11.11ms  p(95)=37.63ms
     browser_first_contentful_paint...: avg=1.75s    min=1.75s   med=1.75s    max=1.75s  p(90)=1.75s    p(95)=1.75s
     browser_first_meaningful_paint...: avg=1.75s    min=1.75s   med=1.75s    max=1.75s  p(90)=1.75s    p(95)=1.75s
     browser_first_paint..............: avg=1.75s    min=1.75s   med=1.75s    max=1.75s  p(90)=1.75s    p(95)=1.75s
     browser_loaded...................: avg=396.64ms min=713µs   med=7.27ms   max=3.92s  p(90)=554.59ms p(95)=1.57s
     data_received....................: 1.2 MB 26 kB/s
     data_sent........................: 8.7 kB 189 B/s
     http_req_connecting..............: avg=139.62ms min=0s      med=42ms     max=542ms  p(90)=409.7ms  p(95)=475.84ms
     http_req_duration................: avg=689.18ms min=78.62ms med=516.49ms max=1.55s  p(90)=1.43s    p(95)=1.49s
     http_req_receiving...............: avg=321.25ms min=8ms     med=137ms    max=1.01s  p(90)=1s       p(95)=1s
     http_req_tls_handshaking.........: avg=86ms     min=0s      med=36ms     max=294ms  p(90)=242.89ms p(95)=268.44ms
     http_reqs........................: 8      0.17385/s
     iteration_duration...............: avg=46.01s   min=46.01s  med=46.01s   max=46.01s p(90)=46.01s   p(95)=46.01s
     iterations.......................: 1      0.021731/s
Is this the full debug log?
@inanc. No its not allowing to paste the full log here there is a limit. Is there any way I can extract the logs to a file and send?
I suggest this one.
https://pastebin.mozilla.org/cY5mhypF
Here also I’m not able to paste the entire log the size too big. You can run this in any windows machine and see you will be able to reproduce this issue.
Unfortunately, I don’t have a Windows machine. I’ll see what I can do. We can tackle this problem if you don’t mind opening an issue on our Github. Please don’t forget to link to this post. Thanks!
@inanc, Raised the below bug and provided this link to this discussion.
Thank you! We’ll consider it in the next planning session (next week or so).
@inanc : I am Facing same issue, we can consider this one Blocker for windows machines. Seems this issue happening due to wait mechanism. While pages are taking longer time for loading, K6 is not waiting for page load, Sometimes DOM got loaded but not actual UI. in that kind of scenarios it forcibly closing the session.
I did tried using below wait Options.
page.waitForLoadState(‘networkidle’);
sleep(15);
sleep(Math.random() * 15);
page.waitForNavigation({ timeout: 100000 });
None of the above methods wait specified until the page get loaded.
Ex : My application will take >=60< seconds to load dashboard page. i tried all the above wait methods for interacting next element after Navigating to dashboard. Obsrved K6 trying to interact element very fast. but all the cases it will not work. then in windows machines we are getting “ERRO[0042] communicating with browser: read tcp 127.0.1.0.1:25484->127.0.1.0.1:25484: wsarecv: An existing connection was forcibly closed by the remote host. category=cdp elapsed=“0 ms” goroutine=88”
Hi @Arjun,
I’ll take another look at this issue soon. Can you please give us the following details to help you further:
  • The OS and version your computer is running. (10 or 11, WSL/WSL2 or powershell).
  • Which version of xk6-browser (was it from the release page, or did you build it yourself?).
  • The full script (pointing to a public website).
  • The log output.
Cheers,
Ankur
@inanc @ankur You have any update on this issue?
You can track our progress from the issue you opened.
Thanks.
