I am trying to setup K6 output to a multi-tenant Mimir deployment via “experimental-prometheus-rw”
I have deployed multi-tenancy enabled Mimir OpenSource in K8s and grafana-agents running on different clusters can send metrics using X-Scope-OrgID header to different tenants successfully.
I cannot manage to set it up for K6 Prometheus Remote Write with “-o experimental-prometheus-rw” option. I have set following variables:
and I see the following error at the end of K6 run:
ERRO[0001] Failed to send the time series data to the endpoint error=“got status code: 401 instead expected a 2xx successful status code” output=“Prometheus remote write”
If I unset “K6_PROMETHEUS_RW_HEADERS_X-Scope-OrgID” environment variable, I see the metrics stored as “anonymous” tenant (default tenant on Mimir if no X-Scope-OrgID defined)
Anyone used Prometheus Remote Write with a multi-tenant Mimir deployment to a specific tenant?
