Expression query in Stat panel
    Grafana 8.1.5; host OS unknown
    In a Stat panel, I have two queries that query AWS CloudWatch. The two queries return the total number of things and the total number of successful things. These two queries perform as I expect and show results as I expect.
I want to create a third query to show percentage of failed things as ($total - $success) / $total * 100. As soon as I add this Math query, the entire panel, including the two queries above that had previously worked, stop returning results.
Not working:
  • What happened?
    All queries returned 0
    Existing 2 queries to continue to return data, third query to do calculations from the first 2 queries
    No
    No
EDIT: Since the screenshots were resized, the expression in the third spot is “($Total - $Success) / $Total * 100” and it is a Math operation.
Welcome to the Grafana community.
Instead of using the alias names ($Total and $Success), try removing those names and use $A and $B, just to see if it works.
Here is what I got using only A and B:
Here is what I got using Total and Success as alias names, but using $A + $B for the expression:
And here is what I got using $Total + $Success:
Obviously, the middle option above is closest to what you want.
You could then do a Display Name override to get what you want:
Thank you, Grant. Regrettably I’m not seeing the same results. Here’s what I was able to do when I renamed my queries back to “A” and “B” and made a math expression in query “C”. Queries A and B work fine and show correct data right up until Query C is added, which is when all three queries show ‘0’.
Are there any known issues in Grafana 8.1.5 that would cause this? I don’t own the application, but if I can point to a fix I might be able to get the company to upgrade.
I tested on the latest version of Grafana in a Docker image and it appears to be working correctly there. (Or, at least, more correctly.) I’ll have to see if I can get I.T. to upgrade our instance.
