Loki Docker Driver plug-in: grafana/loki-docker-driver:2.1.0
Loki Docker image: grafana/loki:2.1.0
I’m using Loki to parse JSON formatted log entries from Docker containers with the Loki Docker Driver plugin. My goal is to create labels that I can use in Loki, as well as produce metrics that I can export to Prometheus.
A sample log entry is as follows:
{"L":"INFO","T":"2021-01-30T06:17:18.876Z","N":"piecestore","M":"download started","Piece ID":"6CYNNMUS6DVVCXOE4N7JNFKXETIZVYBX4PSAVKPY3WPN7VKLVUPQ","Satellite ID":"12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs","Action":"GET_REPAIR"}
The docker-compose.yml
file includes the following pipeline stages for the logging:
section:
x-logger: &logger
logging:
driver: loki
options:
loki-url: "http://172.18.0.250:3100/loki/api/v1/push" # Static IP for Loki container on user-defined bridge
loki-external-labels: job=storj
loki-pipeline-stages: |
- json:
expressions:
loglevel: L
timestamp: T
message: M
satellite: '"Satellite ID"'
action: Action
error: error
errorVerbose: errorVerbose
available_space: '"Available Space"'
- labels:
loglevel:
satellite:
action:
error:
- metrics:
download_started:
type: counter
description: "Total number of downloads started"
prefix: storj_pieces_
max_idle_duration: 24h
source: message
config:
value: "download started"
action: inc
Since there isn’t a Promtail container in this setup, I would expect that the metrics would populate at the Loki container which is accessible on http://localhost:3100/metrics
. However, I see no metrics beginning with the storj_pieces_
prefix as specified above. I can confirm that the JSON parsing and label assignment is successful, having queried the logs using LogQL in Grafana.
Is there a step I have missed in order to get metrics to be available at the Loki container target?
