Facing issue while Configuring Grafana behind a reverse proxy
Hi Team
While configuring Grafana behind a reverse proxy. I am getting 404. I have shared below my changes in configuration file. Please do the needful where am missing. Appreciate your valuable input on this,
Grafana Configuration File[server]
protocol = http
http_addr =
http_port = 3000
domain = example.com
enforce_domain = false
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
serve_from_sub_path = true
NGINX Configuration File
http {
include mime.types;
default_type application/octet-stream;
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream grafana {
server localhost:3000;
#log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
#                  '$status $body_bytes_sent "$http_referer" '
#                  '"$http_user_agent" "$http_x_forwarded_for"';
#access_log  logs/access.log  main;
sendfile        on;
#tcp_nopush     on;
#keepalive_timeout  0;
keepalive_timeout  65;
#gzip  on;
server {
    listen       80;
    #server_name  localhost;
	root /usr/share/nginx/html;
	index index.html index.htm;
	location / {
	proxy_set_header Host $http_host;
	proxy_pass http://grafana;
	# Proxy Grafana Live WebSocket connections.
	location /api/live/ {
	proxy_http_version 1.1;
	proxy_set_header Connection $connection_upgrade;
Getting a 404 https://www.example.com/grafana
Hey Rohit, as mentioned in your nginx config,
You’re proxying requests at “/” to Grafana running at 3000 port.
But in your Grafana config, you’ve mentioned that root URL will be example.com/grafana.
In your nginx config, the /grafana path seem to be missing. Could you please add the below, reload nginx and try to visit the URL ?
  location /grafana/ {
    rewrite  ^/grafana/(.*)  /$1 break;
More on this is perfectly documented here : Run Grafana behind a reverse proxy | Grafana Labs
Hope your issue gets resolved :slight_smile:
Hi Tanmay
As said, i added the same line, But still getting the same error.
http {
include mime.types;
default upgrade;
'' close;
upstream grafana {
sendfile        on;
#tcp_nopush     on;
#gzip  on;
server {
    listen       80;
I tried this setup on my local, and I made it working :
Here’s my nginx config :
events {
    worker_connections   1000;
http {
default upgrade;
'' close;
upstream grafana {
  server grafana:3000;
server {
  listen 80;
  root /usr/share/nginx/www;
  location /grafana/api/live/ {
My grafana config :
[server]
Don’t mind the grafana URL to be grafana instead of localhost since I’m running both nginx and grafana in docker.
Can you validate if grafana is running at 3000 ?
And please cross validate the config I shared with yours.
What happens if you try to serve Grafana at root URL i.e “/”, does it work ?
Hi Tanmay
Thanks for helps.
I am running both grafana & NGINX locally, Is this causing a problem.
I have validated grafana url http://grafana.staged-by-discourse.com/grafana/login, Grafana is running properly.
But after configuring the reverse proxy, https://example.com/grafana. I am getting 404 error.
Grafana Config [Am doing changes in defaults.ini & sample.ini]
The public facing domain name used to access grafana from a browser
#domain = localhost
Redirect to correct domain if host header does not match domain
Prevents DNS rebinding attacks
The full public facing url
Serve Grafana from subpath specified in root_url setting. By default it is set to false for compatibility reasons.
nginx config [ server localhost:3000; I added localhost because grafana is running locally.]
http {
include mime.types;
default upgrade;
'' close;
upstream grafana {
sendfile        on;
#tcp_nopush     on;
#gzip  on;
server {
	listen 80;
    #charset koi8-r;
    #access_log  logs/host.access.log  main;
Even i created a new grafana.ini and perform the same changes its not working with reverse proxy configuration.
I restarted grafana as well.
Hey Rohit, here’s what I’ve done. You can cross verify the below with your config to find out the bug, since the config you shared is not complete or not formatted. Its difficult to read.
First, I’m assuming you’re running running this in Linux. A complete guide on how to configure this is written here.
I ran my setup in Ubuntu.
So for that I’ll edit the defaults.ini.
From doc :
If you installed Grafana using the deb or rpm packages, then your configuration file is located at /etc/grafana/grafana.ini and a separate custom.ini is not used.
Next, I’ve edited the doc for only 3 parameters I’ve shared above.
Here’s my config :
# The http port to use
http_port = 3000
# The public facing domain name used to access grafana from a browser
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
# The full public facing url
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
#....other default config lines
Next, lets look at the nginx config file :
events {
    worker_connections  1024;
http {
include mime.types;
default upgrade;
'' close;
upstream grafana {
sendfile        on;
#tcp_nopush     on;
#gzip  on;
server {
        listen 80;
    #charset koi8-r;
I did a diff of your file and my file and :
diff nginx.conf rohit.conf
1,3c1
< events {
<     worker_connections  1024;
8d5
56,57d52
Only difference between my file and your file is :
  1. events section is missing
  2. Two brackets at the end is missing in your file.
I’m assuming you must be familiar with nginx. Here’s how you can test your nginx file for valid syntax :
nginx -t
Which should give you :
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
Once that’s valid, I added my hosts file with below entry :
127.0.0.1 example.com
And I can visit the web now :
Note : if you’re running a Red Hat flavoured system, additional config is needed for reverse proxy.
Documented here : Install on RPM-based Linux | Grafana documentation
Hi Tanmay
Thanks you so much, am able to set up Reverse Proxy successfully and its running successfully.
One last question while embeding grafana iframe in angular with authentication token in header.
a) In proxy server, How to pass credentials for viever into request headers?
Am getting a CORS issues while accessing the url into angular application.
Error: Access to XMLHttpRequest at ‘http://example.com/grafana/d/ZmqS29WVk/ade?orgId=1&from=now-2y&to=now&random=1661940842000Wed%20Aug%2031%202022%2015:44:02%20GMT+0530%20(India%20Standard%20Time)’ from origin ‘http://localhost:4200’ has been blocked by CORS policy: Response to preflight request doesn’t pass access control check: Redirect is not allowed for a preflight request.
