I don’t have any rules created on loki but upon opening the alerts page on grafana, the errors shown below pop up.
Failed to load rules state from Loki: 404 from rule state endpoint. Perhaps ruler API is not enabled?
Failed to load rules config from Loki: 404 from rules config endpoint. Perhaps ruler API is not enabled?
I couldn’t understand why it was trying to load the rules in the first place if I don’t have any rules. However, I went ahead and created a test rule but that didn’t work as well. I would really appreciate if anyone can share how to go about solving this problem.
/usr/local/bin/loki-local-config.yaml
auth_enabled: false
server:
http_listen_port: 3100
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 5m
chunk_retain_period: 30s
max_transfer_retries: 0
schema_config:
configs:
store: boltdb
object_store: filesystem
schema: v11
index:
prefix: index_
period: 48h
storage_config:
boltdb:
directory: /disk/data/mltmp/loki/index
filesystem:
directory: /disk/data/mltmp/loki/chunks
limits_config:
enforce_metric_name: false
reject_old_samples: false
reject_old_samples_max_age: 48h
ingestion_rate_mb: 25
ingestion_burst_size_mb: 30
max_entries_limit_per_query: 2100000000
max_streams_matchers_per_query: 21000
#unordered_writes: false
chunk_store_config:
max_look_back_period: 0s
table_manager:
retention_deletes_enabled: true
retention_period: 48h
ruler:
storage:
type: local
local:
directory: /etc/loki/rules/rules1.yaml
rule_path: /tmp/loki/rules-temp
alertmanager_url: http://alertmanager:9093
ring:
kvstore:
store: inmemory
enable_api: true
enable_alertmanager_v2: true
The ruler section in the end wasn’t there before, so I added to it to see if that would allow grafana to load a test rule. The rule I created is as follows
rules:
- alert: InstanceDown
expr: 0
for: 30s
labels:
severity: page
annotations:
summary: "Testing rule"
description: "Testing rule"
Do you think this could be a permission issue because I am not able hit the loki endpoints manually except the ready endpoint? All other endpoints throw “404 page not found” error.
