Could you please advise if it’s possible to filter only “message” field from elasticsearch datasource?
I’ve set “Metric” to “Logs” (as I need to display text data) and query like:
(message: “~Disconnected." OR message: "~Net error~”), but the query output contains all elasticseach fields:
while I would like to display only message field, i.e.: “06.01.2020 13:34:05.340; QUIK disconnected”
Thanks in advance!
I have the same problem. Could you solve it?
Regards
Daniel Vallejo
Hi again,
I have seen an option to filter the fields that you want see. If you do click in the log, in each field appear an eye icon.
If you click in this icon only appear in all panel the field selected
