Using promtail, I’m collecting all logs from /var/lib/docker/containers//.log, but I would like to filter out some during ingesting.
I’m currently trying to do this by getting ‘tag’ from the docker logging (json-file), and using a matcher section to filter out anything which does not have a ‘tag’ set, however this does not seem to be working. Is Matcher evaluated before json perhaps? Is there another way to achieve what I want to do?
static_configs:
- targets:
- localhost
labels:
job: docker
# Start promtail with -config.expand-env
host: ${HOSTNAME}
# /var/lib/docker/containers:/logs/containers:ro
__path__: /logs/containers/*/*.log
pipeline_stages:
- docker: {}
- json:
expressions:
# Get tag from logging (json-file)
tag: attrs.tag
- match:
# Drop everything that does not have a tag!
selector: '{tag!=""}'
- multiline:
# WARN 2022-01-25 ...
# DEBUG 2022-01-25 ...
firstline: '^[A-Z]+\s+\d+-\d+-\d+'
max_wait_time: 3s
- regex:
expression: '(?P<level>^[A-Z]+)\s+.*$'
- labels:
tag:
level:
relabel_configs:
- source_labels: [host]
regex: "(.*)"
target_label: __host__
