Hello!
I used to be able to do this with simple regex, but it hasn’t working in awhile. What is the best way to accomplish what I am trying to do:
I am building a graph for an application that has multiple items per host. For example, the “Application: CPU” may have these items:
CPU Nice Time
CPU Steal Time
CPU User Time
CPU Idle Time
Processor Load
Iowait time
And I want to display ALL “CPU” items in the graph but NOT “CPU Idle Time”. What is the best way to exclude this from my graph? This used to work in the item field (many versions ago) but no longer does: /CPU (?!idle)/
Thank you in advance!
Jed
What happened?
Did you follow any online instructions? If so, what is the URL?
