Flux Query with MultiValue Variable
i want to setup a dashboard where you dont need to know or change the flux query.
So the user should be able to select some values from a multiValue variable on the dashboard.
Currently I use Grafana version: 10.0.0
Is there a way to do. The problem is at the moment, that the filter can not handle multiple values in the variable. If one value is selected, it works. If I select more then one, the query won’t work.
Queryexample:
from(bucket: “${database}”)
|> filter(fn: (r) => r[“_measurement”] == “${measurement}”)
|> filter(fn: (r) => r[“host”] == “${host}”)
|> filter(fn: (r) => r[“obj_name”] == “${multiValue}”)
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: “mean”)
I tried already some contain or regex filter, but i could not solve the problem.
Maybe there is someone who could help me with this.
Thank you
Something like this might work.
|> filter(fn: (r) => r["obj_name"] =~ /^${multiValue:regex}$/ )
This thread should help
https://localhost:3000/t/grafana-influxdb-flux-query-for-displaying-multi-select-variable-inputs/35536
This works, thank you.
