Dear,
I am trying to display data in a graph panel on the last 24h of a given date (which is not “now”).
I want to start 24h before my v.timeRangeStop.
I tried the following scrip that works well on Data explorer in influxdata Cloud but not in my Grafana query inspector:
import "experimental"
var_start = experimental.subDuration(d: 24h,from: v.timeRangeStop,)
from(bucket: "env_data")
|> range(start: experimental.subDuration(d: 24h,from: v.timeRangeStop,), stop: v.timeRangeStop)
|> filter(fn: (r) => r["_measurement"] == "co2_daily")
|> keep(columns: ["_time", "_value", "Lieu"])
|> yield()
In Grafana, the “start” date is not the good one.
In Influxdata explore, It works well.
Any advice or workaround?
Best Regards,
Antoine
