Grafana OSS v7.5.7 on CentOS 8 Stream -
Importing folders via the API -
Using the API to import dashboards -
What happened?
Dashboards imported successfully however their folder ID’s don’t seem to match what was in the JSON -
Folder IDs match upon import. Them not matching causes issues on panel types that reference the folder ID for a search (eg. alert list and dashboard list). -
I don’t believe there are relevant config files in this case but if some are needed, I can upload -
No errors in the UI; the import processes returned HTTP code 200 as expected -
Did you follow any online instructions? If so, what is the URL?
Followed docs and standard api practices.
