Formatting legend in grafana with prometheus source + adding sometext
reading the docs here on formatting the legend in grafana from prometheus source.
I want to have all inside the {} from prometheus to show with some text appended eg the name of the counter
so instead of speifying the parameters {{method}} - {{status}} I want to have all inside the curly brackets followed by some text {<all inside the curly brackets>} someText.
in this case the someText is the counter name.
For example leaving the legend bland will show all inside the curly brackets but then it won’t show the counter name, because I am using the rate in my query.
    8.04
    above
    above
  • What happened?
    above
    above
    above
    n/a
    above
ref1
