From a dashboard panel view, i.g. viewPanel=<panel_id>, is there a way to see entire dashboard without changing (removing viewPanel=xxx part) url? Or do I have to have a text box on the panel to link it back to the parent dashboard? That sounds bit awkward…
-S
Hi @marathiboy,
Thanks for opening this post.
Please provide some more details and if possible some screenshots with examples as what you want to achieve as currently, I do not understand that well what exactly you are looking for.
Thanks.
