Gauge Panel do not display gauge if null/empty value
  • Grafana version
    Grafana 8.0.3
    Displaying gauge even if value is null.
    By using Gauge panel with multiple queries (A, B and C).
  • What happened?
    If a query returns “null” or “no data”, no gauge is shown for the concerned serie (if Query B returns “no data”, I only get 2 gauges, A and C)
    Showing an empty gauge if no data
Thanks for help!
Hi I have exactly the same problem, did you ever get to resolve this issue?
cheers
Yes, I fixed it by using nested queries instead of 3 simple ones.
I customized than my null values in panel standard options:
Hope it will help
