- What Grafana version and what operating system are you using?
Grafana v9.3.2 on openSUSE Leap 15.4 - What are you trying to achieve?
I’m trying to visualize login attempts per country on a GeoMap panel using two letter country codes. - How are you trying to achieve it?
I have an InfluxDB with fail2ban data containing the number of hits as a value and the 2 letter country code that I got from the IP address as a tag.
The query output actually shows data. The data selection also shows that there are 41 rows in the query output.
I wanted to use the value as size of the marker but since I did not get anything shown on the map I set it to fixed. - What happened?
An empty map is shown - What did you expect to happen?
Show markers on the map at the locations of the countries. - Can you copy/paste the configuration(s) that you are having problems with?
This is the dashboard JSON:
"annotations": {
"list": [
"builtIn": 1,
"datasource": {
"type": "grafana",
"uid": "-- Grafana --"
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"target": {
"limit": 100,
"matchAny": false,
"tags": [],
"type": "dashboard"
"type": "dashboard"
"editable": true,
"fiscalYearStartMonth": 0,
"graphTooltip": 0,
"id": 9,
"links": [],
"liveNow": false,
"panels": [
"datasource": {
"type": "influxdb",
"uid": "CKj-yZ2Vk"
"fieldConfig": {
"defaults": {
"color": {
"fixedColor": "red",
"mode": "fixed"
"custom": {
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "none"
"overrides": []
"gridPos": {
"h": 16,
"w": 17,
"x": 0,
"y": 0
"id": 2,
"options": {
"basemap": {
"config": {
"showLabels": true,
"theme": "auto"
"name": "Layer 0",
"opacity": 1,
"tooltip": true,
"type": "carto"
"controls": {
"mouseWheelZoom": true,
"showAttribution": true,
"showDebug": false,
"showMeasure": false,
"showScale": false,
"showZoom": true
"layers": [
"config": {
"showLegend": false,
"style": {
"color": {
"fixed": "red"
"opacity": 1,
"rotation": {
"fixed": 8,
"max": 360,
"min": -360,
"mode": "mod"
"size": {
"fixed": 5,
"max": 30,
"min": 1
"symbol": {
"fixed": "img/icons/marker/circle.svg",
"mode": "fixed"
"text": {
"field": "",
"fixed": "",
"mode": "fixed"
"textConfig": {
"fontSize": 12,
"offsetX": 0,
"offsetY": 0,
"textAlign": "center",
"textBaseline": "middle"
"filterData": {
"id": "byRefId",
"options": "A"
"location": {
"gazetteer": "public/gazetteer/countries.json",
"lookup": "country_code",
"mode": "lookup"
"name": "Origin",
"opacity": 0.7,
"tooltip": true,
"type": "markers"
"tooltip": {
"mode": "details"
"view": {
"allLayers": true,
"id": "zero",
"lastOnly": false,
"lat": 0,
"layer": "Hack origin",
"lon": 0,
"shared": false,
"zoom": 2
"pluginVersion": "9.3.2",
"targets": [
"datasource": {
"type": "influxdb",
"uid": "CKj-yZ2Vk"
"groupBy": [
"params": [
"country_code"
"type": "tag"
"hide": false,
"measurement": "fail2ban",
"orderByTime": "ASC",
"policy": "default",
"query": "SELECT sum(\"failures\") FROM \"fail2ban\" WHERE $timeFilter GROUP BY \"country_code\"",
"rawQuery": true,
"refId": "A",
"resultFormat": "table",
"select": [
"params": [
"failures"
"type": "field"
"params": [],
"type": "sum"
"tags": []
"title": "Login attempts per country",
"transparent": true,
"type": "geomap"
"refresh": "5m",
"schemaVersion": 37,
"style": "dark",
"tags": [],
"templating": {
"list": []
"time": {
"from": "now-2d",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "Hack",
"uid": "jck_9ZhVz",
"version": 20,
"weekStart": ""
Did you follow any online instructions? If so, what is the URL?
- Thanks in advance for your help.
