Grfana V10.0
InFluxDB 2.7
With this below I get one point
from(bucket: "flood")
|> filter(fn: (r) => r["tag1"] == "Kwezimbovu")
|> filter(fn: (r) => r["_field"] == "Site" or r["_field"] == "battery" or r["_field"] == "latitude" or r["_field"] == "level" or r["_field"] == "longitude")
|> last()
|> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
|> drop(columns: ["_start", "_stop", "_measurement"])
If I add the or in the “tag” I still get only one geo point displayed
|> filter(fn: (r) => r["tag1"] == "Kwezimbovu" or r["tag1"] == "Landulwazi" or r["tag1"] == "Mabedlana")
|> last()
Any help will be appreciated, thank you
Welcome @mwengiineeringbuild
Might be because you are using
|> last()
please follow this thread here.
https://localhost:3000/t/grafana-geomap-with-influxdb/88772/11
Also we dont have access to your influxdb so you might want to share sample data as show in above thread
I have 3 sites and they are “Kwezimbovu”, “Landulwazi” and “Mabedlana” those I made the tags.
Then each site have 5 fields - “Site”, “battery”, “latitude”, “level”, “longitude”
I only want to display the last record of each o the sites.
Would you structure the data differently? (the only record really varying is the ‘level’)
So Sites have sub site?
Also as far as design I guess it depends but look at documentations. For tags you do not want something with high cardinality, meaning changes a lot like a guid. but the sites I would not use them as tags, I would put those as field sets
InfluxDB uses line protocol to write data points. It is a text-based format that provides the measurement, tag set, field set, and timestamp of a data point.
floods,tag1=Maqwath loc=Kwezimbovu latitude=52.4943817 1687867620000000000
floods,tag1=Maqwath loc=Kwezimbovu longitude=52.4943909 1687867620000000000
floods,tag1=Maqwath battery=23.5 1687867620000000000
or
floods,tag1=Maqwath loc="Kwezimbovu",latitude=1i, latitude=
Thank you, have amended the structure, I understand the limiting the cardinality.
How do I select the last or each site?
|> filter(fn: (r) => r["_measurement"] == "flood")
|> filter(fn: (r) => r["tag1"] == "KZN")
|> drop(columns: ["_start", "_stop", "_measurement", "type"])
As this retunes all the records for each site.
This is the same issue i reported a few months ago. No solution was found and i had to move out of Graphana…
