Geomap with influxdb2.0
Hi, I would like to use geomap with influxdb2.0.
How do I set latitude and longitude for Line Protocol?
I tried below 2 items, but geomap did not show A.
test,tag=test1,latitude=55,longitude=0 A=10
test,tag=test1 A=10,latitude=55,longitude=0
And, How do I write query on Grafana?
from(bucket: "my_bucket")
  |> filter(fn: (r) => r["_measurement"] == "test")
  |> filter(fn: (r) => r["tag"] == "test1")
  |> filter(fn: (r) => r["_field"] == "A" or r["_field"] == "latitude" or r["_field"] == "longitude")
  |> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
  |> yield(name: "last")
I guess grafana has any problem.
I wrote below line protocol to influxDB.
Then, Grafana shows latitude and longitude fileds.
And, I set the location on the data layer to coords.
However, latitude and longitude must set same field value.
for example,
latitude on data layer= latitude{tag=“A”,latitude=“55”,longitude=“0”}
longitude on data layer= latitude{tag=“A”,latitude=“55”,longitude=“0”}
Or
latitude on data layer= longitude{tag=“A”,latitude=“55”,longitude=“0”}
longitude on data layer= longitude{tag=“A”,latitude=“55”,longitude=“0”}
This behavior is abnormal.
Please check and fix it.
This solves the issue
https://localhost:3000/t/cant-visualize-my-data-with-the-geomap-plugin/58791/2?u=z3ky
Use the merge transformation.
