I’m not aware of the getTheme function, but the output you’re getting is because the theme is an object. I believe there should be a theme.isDark() method if you only want to check if light or dark theme is set.
I’m afraid I don’t understand your answer. What components do you mean? The basis of my panel is the Multistat Panel by Michel D. Moore. Here is another code excerpt with your built-in answer:
/*jshint esversion: 6 */
/*jshint -W087 */
/*jshint -W014 */
import { MetricsPanelCtrl } from "app/plugins/sdk";
import $ from "jquery";
import "jquery.flot";
import _, { constant } from "lodash";
import moment from "moment";
import "./css/multistat-panel.css!";
import d3 from "./external/d3.min";
import { getTemplateSrv } from '@grafana/runtime';
import appEvents from "app/core/app_events";
import { AppEvents } from "@grafana/data";
import {
// DataQuery,
// DataQueryResponseData,
// PanelPlugin,
PanelEvents,
// DataLink,
// DataTransformerConfig,
// ScopedVars,
import { getTheme } from '@grafana/ui';
const templateSrv = getTemplateSrv();
class MultistatPanelCtrl extends MetricsPanelCtrl {
onRender() {
if (this.data != null && this.data.rows && this.data.rows.length) {
var cols = this.cols;
var dateTimeCol = -1;
var unitCol = 0;
var labelCol = -1;
var valueCol = 0;
var sortCol = 0;
var groupCol = -1;
var recolorCol = -1;
var lowCol = 0;
var highCol = 0;
var minLineCol = -1;
var baselineCol = -1;
var maxLineCol = -1;
var alarmCol = -1;
var info1Col = -1;
var info2Col = -1;
var info3Col = -1;
var info4Col = -1;
for (let i = 0; i < cols.length; i++) {
if (cols[i] == this.panel.DateTimeColName) dateTimeCol = i;
if (cols[i] == this.panel.UnitColName) unitCol = i;
if (cols[i] == this.panel.LabelColName) labelCol = i;
if (cols[i] == this.panel.ValueColName) valueCol = i;
if (cols[i] == this.panel.SortColName) sortCol = i;
if (cols[i] == this.panel.GroupColName) groupCol = i;
if (cols[i] == this.panel.RecolorColName) recolorCol = i;
if (cols[i] == this.panel.LimitLowColName) lowCol = i;
if (cols[i] == this.panel.LimitHighColName) highCol = i;
if (cols[i] == this.panel.MinColName) minLineCol = i;
if (cols[i] == this.panel.BaseLineColName) baselineCol = i;
if (cols[i] == this.panel.MaxColName) maxLineCol = i;
if (cols[i] == this.panel.AlarmColName) alarmCol = i;
if (cols[i] == this.panel.Info1Col) info1Col = i;
if (cols[i] == this.panel.Info2Col) info2Col = i;
if (cols[i] == this.panel.Info3Col) info3Col = i;
if (cols[i] == this.panel.Info4Col) info4Col = i;
//console.log('onRender: this.data.rows\n'+JSON.stringify(this.data.rows));
var gt = getTheme();
console.log("Theme: " + gt); //returns Theme: [object Object]
console.log("Theme gt.isDark: " + gt.isDark); // returns true regardless of whether dark or light is set
console.log("Theme gt.isLight: " + gt.isLight); //returns false regardless of whether dark or light is set
When I use your useTheme, the panel does not start at all.
Sorry for the confusion. I assumed that you’re using the current (React) plugin platform. I can see from your example that you’re building a legacy (Angular) plugin.
Unfortunately, I’m not that familiar with building Angular plugins, but I’m not sure whether the GrafanaTheme actually works with Angular plugins. You may need to find the legacy equivalent of getTheme.
