Hi Team,
Is there anyway to get panel output use API[curl] in the bash script. I wanted to make use of that data to do something else.
Thanks,
Vadiraj
What does that mean?
Hi @yosiasz, thanks for pretty quick response.
I would like to extract panel output data in JSON format from the external script if not can we directly query any using data source endpoint to get the same output.
Thanks,
Vadiraj
How different is this request compared to this
https://localhost:3000/t/removing-meta-data-from-grafana-api-response/69320/14
Hi @yosiasz ,
Sorry for the inconvenience, some extend you are correct with referring to old ticket. Let me try with the data source and come back if any issue.
thankyou for your support and help as always.
