I have enabled GitHub OAuth and user’s are able to login via GitHub into Grafana. Evertyhing seems to work as expected that everyone are autoassigned to Viewer Role by default.
Grafana v8.0.5, deployed via Helm Chart. -
Is it possible to achieve that i.e. GH Organization Admin/Owners will be attached to Admin role in Grafana, and rest of the users will have Editor role by default ? Is it somehow possible ? -
What happened?
Authorized user have only Viewer permissions. -
auth.github:
enabled: true
allow_sign_up: true
scopes: user:email,read:org
auth_url: https://github.com/login/oauth/authorize
token_url: https://github.com/login/oauth/access_token
api_url: https://api.github.com/user
team_ids:
allowed_organizations: mycompany
client_id: xxx
client_secret: xxx
