Graf lagging Stat
Hi there,
just started with InfluxDB & Graphana, logging a single temperature / RH sensor. At the beginning the graph panel did not complain about missing data, but also showed no data. But the Stat panel did. So i continued with this.
When bragging to my wife later, she asked “why are there no axis?” - so i tried graph again → now it worked o.O.
Today I noticed: they are not in sync but delayed by ~ 45minutes:
Query is the same for both:
Object
request:Object
method:“POST”
url:“api/datasources/proxy/1/query”
params:Object
db:“BME280_trial”
epoch:“ms”
data:“q=SELECT%20%22Temperature%22%20FROM%20%22ambient_values%22%20WHERE%20time%20%3E%3D%20now()%20-%203h”
precision:“ms”
response:Object
results:Array[1]
0:Object
How do I get rid of this lag?
Nobody ? :face_with_monocle:
We need more information. For example, queries for both might help. Also, the dashboard settings usually control how often data is refreshed.
The query is included in the first post, it’s the same for both.
As for refreshing, they do refresh together and both react to new time periods as expected, with the Graf lagging the Stat.
Am I really the only one with this problem?
