Grafana 8: gauges in tables not working anymore?
Hi, I had a table that filled some cells with a basic gauge based on the cell value. In Grafana 7 this worked well, but since the upgrade it does not anymore. This is on the standalone installation.
    Grafana 8, Ubunti 20.04 LTS
    Add a basic gauge in a table
  • What happened?
    After upgrading to Grafana 8 the gauge we had disappeared.
    For the gauge to remain there. This used to show a gauge (don’t have a screenshot).
Still having the same issue.
This is just a table from SQL Server with a cell set to display a basic gauge
What am I doing wrong?
Same here. Anyone know how to fix this? Is it a v8 bug?
Screenshot 2021-07-15 144541
Same here after an upgrade from v7.5.5. to v8.0.6.
Solution/fix would be highly appreciated.
Just tested this again on Grafana version 8.1.0 which was released yesterday. Seems the bug is still there. Anybody that knows how to resolve this?
I’ve had to “downgrade” all my graphs and remote it. Would really be great if some developer could answer: are we doing something wrong (i.e. the mechanism was changed) or is it a known bug being worked on?
Looks like a bug, but a 30-second search didn’t show up anything on GitHub. Best report it there: Sign in to GitHub · GitHub
I have opened a case for this in Github: Gauge display issue in table panels in Grafana 8 · Issue #37635 · grafana/grafana · GitHub
Case is updated as issue is not resolved in version 8.2.2
Ran into the same issue. I was able to get it working in a test environment by changing the field type to String instead of Numeric.
Your figures are too low.
Multiply with 100 and use Percent 0-100 as a unit
(max(hz_memory_usedHeap{mc_member!=“”}) by (mc_member,mc_cluster)/max(hz_memory_maxHeap) by (mc_member,mc_cluster))*100
Ps: I am using Grafana v8.3.6 (bf8766bbf2)
