Grafana alert thresholds from environment variable
I am using grafana 9.4.9
I created an alert rule with math expression $B > 10.0 (I. E. Alert if value exceeds 10)
Now I want to make this threshold configurable via environment variables during provisioning.
I tried writing the rule as
$$B > ${MY_ENV_VAR}
But this creates error ‘Failed to build rule evaluator’.
Is there anything else I can do about it?
Welcome @maloyghosh
If you are using InfluxDB with Flux, @fercasjr came up with a solution here.
