Grafana Alerts - hiding markers on dashboard panels for Alert status
Hi - I am in the process of setting up a few alerts in Grafana for a couple different dashboard panels. I noticed that it shows vertical markers for each “Alerting” status and each “OK” status. That’s great to be able to see when/where it triggered, however, it dirties up the panel-graph and makes it look more confusing such that I see a bunch of extra vertical lines when trying to look at the graph from afar.
Is there a way to suppress these markers?
Thanks.
Stephan
Same problem here. How to disable it?
Any update on this? Alerts using conditions like diff are coloring most of the graph without any useful addition…
Yes, you can disable them now.
Go into the settings of the panel, choose “Panel” on the right, scroll down and open “Display” and disable “Alert thresholds”.
