Grafana can't connect with Oracle DB
Hi there, I’m having problems using the Oracle plugin to connect with a Database, I’m trying to test the connection but it never returns a successful message, then when I’m trying to query the database, I’m getting a 504 error.
Can someone please help me with this?
Thank you.
To troubleshoot, i would suggest the following :
1 - Check connectivity from grafana server to your oracle db (use telnet host port)
2 - Then check that the user you are using have privileges, if this is not the case you will have events on your oracle database (audit)
Hope it helps.
Good Luck
