Grafana 8.2.1 on Linux with Docker -
Dynamically control the dashboards and datasources using API/CLI. -
grafana-cli
, there might be a way with API but I’m not sure why. -
What happened?
The CLI tool is pretty limited. -
So I’ll be able to export/import dashboard and manipulate datasources. -
Irrelevant. -
Nope, I can do it in the UI, it’s useless. -
Did you follow any online instructions? If so, what is the URL?
Sure:
Grafana CLI | Grafana documentation
Thanks.
