What happened?
Data time from logs is not synchronized with the dashboard time -
Did you follow any online instructions? If so, what is the URL?
Hi @eddgua23,
Welcome to the Community forum;
Can you please provide us with more information from the questionnaire forum?
It seems that you by mistake paste it and forgot (or overwritten) the information you wanted to provide to us.
Hi Usman,
Can I share with you the information through this email address?
Regards,
You can share on the forum so that other community members can also view it and help you out.
You can remove any secrets e.g. password credentials, tokens, api-end points etc.
