Grafana + flux - Not able to download all data to 1 file using inspect data from a graph panel
    Grafana Cloud v8.0.3 and macOS
    I want to present the time series data in a plot panel and allow the client to download data from the panel using the inspect data option.
    I’m using the old graph panel to plot my time series data. All of my data is store in InfluxDB and I’m using flux to retrieve data.
  • What happened?
    When I tried to download CSV file using inspect data, I was not able to download all the columns in 1 file. Under data options, when I selected the “Series joined by time” from the “Show data frame” drop-down list, it will show no data. I can only download 1 column of data at a time by selecting other drop-down options under “Show data frame”. I’m not sure how I can download all of the data other than using “Series joined by time”.
    Previously when I use InfluxQL to retrieve data, I can download all of the data by selecting “Series joined by time” from the “Show data frame” drop-down. However, after I switch to flux, I was not able to do this anymore. Is this an issue with flux? Or is there any function I can use in flux to resolve this issue? Also, I noticed that after Grafana is updated to v8, the graph panel we use previously become “Graph (old)”. Not sure if this is the cause of this issue. I also tried to use the time series panel to plot my data but still couldn’t achieve what I want.
    When I tried to use “Series joined by time” from the “Show data frame” drop-down to download all the data, it shows no data.
    No.
    No, I haven’t found any post similar to this.
