I’m new to grafana.
Yesterday i created a Graph in Grafana and everythink works fine, the data are displayed (see Screenshot below).
But Grafana doesn’t display values for min,max,average.
As you can see on the Screenshot, i guess i have enabled everything i need.
Do you know where the Problem could be?
regards,
Simon
I figured something out, normally the values on this graph are floats.
If I convert the values to a integer it works.
Is it a normal behaviour that grafana doesn’t “create” the min,max,avg if the values are floats??
Ok, thats only partly correct.
An other Graph gets only Integer and it does nit show the values…
I have really no idea whats going on
Have anybody a Idea?
