Grafana max number of data points for display
Hi All
I use Grafana to display 5 minute sensor data. Over 1 day the data visualises as expected. If the period is increased to say 1 month then I get the following error
A query returned too many data points and the results have been truncated at 4521 points to prevent memory issues. At the current graph size, Grafana can only draw 452.
I have added aggregateWindow as per following which corrects the issue and the data displays correctly for the longer period but when I go back to 1 day time period the data is truncated and not as visaully appealing as without the aggreegateWindow function
from(bucket: "home")
  |> range(start: v.timeRangeStart, stop:v.timeRangeStop)
  |> filter(fn: (r) => r._field == "SOC")
  |> aggregateWindow(every: v.windowPeriod, fn: mean)
Outputs with and without
Is there anyway to make this more dynamic based on the time period?
Hi @davidmartin1408,
Not sure but did you try the Query option where you can change the max data points?
Here is a reference screenshot:
Let us know if this helps.
Hi @davidmartin1408
Did you find a solution or is this is still on-going?
We would like to know the updated status :slight_smile:
All good as per your advise. Thanks
