I’m trying to start grafana-server on a raspberry pi zero
sudo /bin/systemctl status grafana-server
● grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Fri 2021-02-26 18:36:29 GMT; 3s ago
Docs: http://docs.grafana.org
Process: 2866 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} c
Main PID: 2866 (code=killed, signal=ILL)
Feb 26 18:36:29 raspberry systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
Feb 26 18:36:29 raspberry systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Feb 26 18:36:29 raspberry systemd[1]: Stopped Grafana instance.
Feb 26 18:36:29 raspberry systemd[1]: grafana-server.service: Start request repeated too quickly.
Feb 26 18:36:29 raspberry systemd[1]: grafana-server.service: Failed with result 'signal'.
Feb 26 18:36:29 raspberry systemd[1]: Failed to start Grafana instance.
lines 1-13/13 (END)
The folder /var/log/grafana
is empty.
melrose
February 26, 2021, 7:23pm
2
[quote=“thalasso, post:1, topic:43736”]
[/quote
hello thalasso, welcome to the forums, and a lot of fun with your grafana. best wishes
Hello melrose, thank you!
Do you have any idea what to do about the issue?
I have uninstalled grafana from the apt repository and reinstalled it via .deb package:
sudo apt-get install -y adduser libfontconfig1
wget https://dl.grafana.com/oss/release/grafana-rpi_7.4.3_armhf.deb
sudo dpkg -i grafana-rpi_7.4.3_armhf.deb
Now it’s working. But I’d prefer to install it from repository to get automated updates.
melrose
February 28, 2021, 10:37am
5
yes try again it shall work
No, it doesn’t. Same error as before.
and what did you do different
I didn’t do anything different.
Hello Thalasso
I’ve the same issue, did you find a solution ?
what is in
/var/log/syslog
after a grafana restart ?
what exact hardware is your rasbety?
Hello Thalasso
Where did you set the log to go?
E.g. in defaults.ini or custom.ini
or grafana.ini
Directory where grafana can store logs
logs = data/log
That means under your grafana folder.
I do not think for raspberry this is any different.
For /var/log there are usually special rights required, e.g. in my installation only root can write there. Does the grafan user have rights to write there?
BR, Daniel
I have installed grafana with apt command but it doesn’t works … So I tried with dpkg and now it work. But if someone know how it can run with apt command, I would prefer
BR, Cédric
todskv
June 19, 2022, 5:45am
13
Go to:
/usr/share/grafana
and run from that folder, first time
sudo grafana-server
