Hi, i’m new to grafana. I have completed installing the grafana but page is not loading. any idea where i missed installing some packages?
t=2020-12-20T22:29:13-0500 lvl=info msg=“Shutdown started” logger=server reason=“System signal: terminated”
t=2020-12-20T22:29:13-0500 lvl=info msg=“Starting Grafana” logger=server version=7.3.6 commit=ea06633c34 branch=HEAD compiled=2020-12-14T04:19:44-0500
t=2020-12-20T22:29:13-0500 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2020-12-20T22:29:13-0500 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
t=2020-12-20T22:29:13-0500 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
t=2020-12-20T22:29:13-0500 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
t=2020-12-20T22:29:13-0500 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
t=2020-12-20T22:29:13-0500 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
t=2020-12-20T22:29:13-0500 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
t=2020-12-20T22:29:13-0500 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
t=2020-12-20T22:29:13-0500 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
t=2020-12-20T22:29:13-0500 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
t=2020-12-20T22:29:13-0500 lvl=info msg=“Path Provisioning” logger=settings path=/etc/grafana/provisioning
t=2020-12-20T22:29:13-0500 lvl=info msg=“App mode production” logger=settings
t=2020-12-20T22:29:13-0500 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=8961
t=2020-12-20T22:29:13-0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-12-20T22:29:13-0500 lvl=warn msg=“SQLite database file has broader permissions than it should” logger=sqlstore path=/var/lib/grafana/grafana.db mode=-rw-r–r-- expected=-rw-r-----
t=2020-12-20T22:29:13-0500 lvl=info msg=“Starting DB migrations” logger=migrator
t=2020-12-20T22:29:13-0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2020-12-20T22:29:13-0500 lvl=info msg=“Registering plugin” logger=plugins id=input
t=2020-12-20T22:29:13-0500 lvl=info msg=“HTTP Server Listen” logger=http.server address=[::]:3000 protocol=http subUrl= socket=
netstat -plntu
(No info could be read for “-p”: geteuid()=9021 but you should be root.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:9102 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp6 0 0 :::3000 :::* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
udp 0 0 0.0.0.0:514 0.0.0.0:* -
udp6 0 0 :::514 :::*
[mahp004@fbextt-01 ~]$ wget http://192.168.1.1:3000
–2020-12-20 22:31:14-- http://192.168.1.1:3000/
Connecting to 192.168.1.1:3000… connected.
] 27,951 --.-K/s in 0s
2020-12-20 22:31:14 (452 MB/s) - ‘index.html’ saved [27951]
[mahp004@fbextt-01 ~]$ sudo firewall-cmd --add-port=3000/tcp --permanent
FirewallD is not running
