I am facing an issue with Grafana Pie Chart when querying using aggregation functions like sum global time range changes are not reflecting and always display whole data queried applied with latest time stamp.
sum by (sourceSystem, requestType) (component_counter_total{application="$application", componentClass=“abc”, status=“start”})
Thanks,
Vijay
I think the community has the best chance of helping if you can share either: A screenshot of your data as it appears in the table visualization. Or your raw unformatted data from the inspect drawer
Also, please try to follow the topic template. The community does not even know what version of Grafana you are running. Grafana develops very rapidly, and this is critical information
