Grafana Reverse proxy for Apache is not working
I tried to configure reverse proxy to enable auto login using the domain (IP) using this - http://docs.grafana.org/installation/behind_proxy/#running-grafana-behind-a-reverse-proxy
Below is my httpd.conf
<VirtualHost *:80>
ServerAdmin webmaster@authproxy
ServerName authproxy
ErrorLog "logs/authproxy-error_log"
CustomLog “logs/authproxy-access_log” common
<Proxy *>
    AuthType Basic
    AuthName GrafanaAuthProxy
    AuthBasicProvider file
    AuthUserFile /etc/apache2/grafana_htpasswd
    Require valid-user
    RewriteEngine On
    RewriteRule .* - [E=PROXY_USER:%{LA-U:REMOTE_USER},NS]
    RequestHeader set X-WEBAUTH-USER "%{PROXY_USER}e"
</Proxy>
RequestHeader unset Authorization
ProxyRequests Off
ProxyPass / http://IP:3000/
ProxyPassReverse / http://IP:3000/
content of /etc/apache2/grafana_htpasswd admin:badminton:
grafana.ini
;domain = http://IP
;root_url = http://IP:3000/
#################################### Auth Proxy ##########################
[auth.proxy]
;enabled = true
;header_name = X-WEBAUTH-USER
;header_property = username
;auto_sign_up = true
;ldap_sync_ttl = 60
;whitelist =
can you please help
Have you read the authproxy documentation?
Marcus
