Grafana Shell Importer
Hello All,
I am currently using Grafana for my University Project and I am fairly happy so far.
My only problem is, that I dont know if I am able to import a predesigned Dashboard on a fres grafana installation from the command line.
I am installing Grafana on a Raspberry Pi and have to load my existing Dashboard with the console.
I found a Shell Importer Script on github, but so far I am concerned about the API Key and the Organization. How do i configure this script for a brand new Installation.
Instructions from my Professor are clear “no use of any graphical interface”.
I would be very happy if you could help me out.
Thank you all very much in advance!
Did you see this guide?
http://docs.grafana.org/tutorials/api_org_token_howto/
I did not see that. Will check it out, thank you!
