We are having jitsi-meet instance hosted on AWS ec2 instance. We are also having Grafana Server which is on AWS ec2 instance.
We are not able to access Stats of jitsi-meet instance on Grafana server though Firewall is turned off. We have configured Grafana correctly, but still getting following errors:
curl -v http://X.X.X.X:8080/colibri/stats
Trying X.X.X.X…
TCP_NODELAY set
connect to X.X.X.X port 8080 failed: Connection refused
Failed to connect to X.X.X.X port 8080: Connection refused
Closing connection 0
curl: (7) Failed to connect to X.X.X.X port 8080: Connection refused
Well, your output of netstat shows that nothing is listening on any address on
port 8080, therefore it’s not surprising that Grafana is complaining that it
cannot connect to it.
Er, you did run this command on the machine with IP address X.X.X.X, I hope?
Beyond that, I can’t say what your problem is - given that you seem to be
expecting jitsi-meet to be offering these stats on port 8080, and it clearly
isn’t (in fact I do not see a Jitsi service listening on any port, so I
wonder how it is working at all), I suggest that you’re better off
investigating this with the Jitsi support people rather than Grafana, since
there clearly isn’t anything available for Grafana to work with.
If they come and back tell you that this really is a Grafana problem, by all
means come back with some details and someone may be able to help.
Hi Antony,
Thanks for your response.
We are able to access Grafana Dashboard with old release of Jitsi-Meet but with their latest version, we are getting port 8080 connection refused error though port is open in Firewall.
All I can say to that is that the current version of Jitsi-meet doesn’t appear
to listen on port 8080, therefore you cannot monitor it in the same way as the
old version.
I suggest asking for more assistance on the Jitsi list.
You cannot just tell telegraf to connect to any port number you like. That
would be like arbitrarily thinking up a telephone number and trying to contact
a friend by simply dialling it, without checking whether it is their number.
You have to tell telegraf to connect to the port number which Jitsi is
listening on, and from the netstat output you posted yesterday, Jitsi is not
listening on any ports at all - if it were, the name “jitsi” or similar would
have appeared in the final column of the netstat output.
I did ask a question about this, and it would be helpful if you gave the
answer - did you run that netstat command on the machine you believe Jitsi is
running on?
If not, please do so.
If you did, can you see Jitsi running in the output of “ps ax” or similar?
