I am using the latest Grafana version 10.0.0, and the “time series” plugin is driving me crazy After a lot of trial and error, I finally managed to get the graphs set up the way I wanted. However, I’m now struggling with the output in the legend. Currently, it only displays the “host” as a tag in the result and not any other columns. How can I influence which tags are generated as a result in a Flux query? Additionally, even if I have the entry in a separate column, I haven’t been able to use the value from a specific column in the legend (each row has the same value in this column per table).
so i want to use the column rname
as legend.
